RME netconfig
Feb 5th, 2009
Hello, I try to apply some commands to several devices but when i going to select de devices some check box are enable for select but the other don't. the same happens with the archive task, only can collect some devices but not all, and the RME generate the follow error. (CM0056 Config fetch failed for RT-SERLEFIN Cause: CM0204 Could not create DeviceContext for 640 Cause: CM0206 Could not get the config transport implementation for 172.22.133.1 Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.)
thanks
Jose Luis ARango
Joe Clarke Thu, 02/05/2009 - 13:21
It looks like you're missing the device package for these devices. What version of RME do you have? What is the sysObjectID of these devices?
