Busy Boot-Up, Up then Down
Feb 5th, 2009
I have 2 uBR's (7100 series), One boots up fairly normal going directly to the: Router>
The other (see attached) boots up in an indecisive manner with interfaces up, then down, then up, then down, then ...well, you get the picture.
How might I eliminate the unit from doing this?
mchin345 Thu, 02/12/2009 - 14:05
  • Silver, 250 points or more
The error %LINK-3-UPDOWN: states the data link level line protocol changed state. If the state change was unexpected, confirm the configuration settings for the interface and line protocol. The SNMP server has undergone a cold start.
LeeNorman Thu, 02/12/2009 - 18:08
From what I know, all interfaces should be up at Boot-Up.
I'm only at odds why they go up, then down, then up, etc., etc., during Boot-Up.
How do I stop that?
