Changing Admin Distance of EIGRP
Feb 5th, 2009
Hi Guys,
I would like to change the admin distance of eigrp learned routes from the neighbor 172.20.248.3. When I am using:
distance 130 172.20.248.3 255.255.255.255
It's setting all eigrp routes to AD=130. Any thoughts how to get around with it?
switch1.bdb.qld#show ip eigrp neighbors
IP-EIGRP neighbors for process 109
H Address Interface Hold Uptime SRTT RTO Q Seq Type
(sec) (ms) Cnt Num
1 176.20.88.49 Vl24 11 00:19:16 54 324 0 883463
0 172.20.248.3 Vl406 13 00:19:17 1 200 0 1165020
Istvan_Rabai Thu, 02/05/2009 - 22:34
  • Gold, 750 points or more
Hi Shawkat,
The command is the following:
distance 130 172.20.248.3 0.0.0.0 [ACL number],
where the mask is a wildcard mask, not a normal subnet mask.
So 0.0.0.0 wildcard mask will identify the ip address of the ONE source router: 172.20.248.3
You can define the routes with the acl, for which to change the admin distance.
Cheers:
Istvan
shawkatalvi Sun, 02/08/2009 - 03:37
Thanks Istvan. I put the wild card mask incorrectly. Now the received eigrp routes are 130. But still router is preferring these eigrp AD=130 routes over RIP learned routes (AD=120), any idea why it's doing it?
Istvan_Rabai Sun, 02/08/2009 - 09:43
Hi Shawkat,
You should inspect the rip and eigrp routes more closely.
1. maybe the rip routes are not 120,
or
2. maybe the routes learned by eigrp are not learned by rip, therefore the route table process has the only choice of eigrp routes.
Cheers:
Istvan
shawkatalvi Sun, 02/08/2009 - 13:45
Hi Istvan,
RIP V2 routes are 120 for sure and they are learning the same EIGRP routes!! I am redistributing eigrp into rip like this:
router eigrp 109
redistribute static
passive-interface Vlan120
passive-interface FastEthernet0/23
network 172.20.0.0
network 176.20.0.0
no auto-summary
router rip
version 2
redistribute eigrp 109 metric 2
passive-interface Vlan7
passive-interface Vlan24
passive-interface Vlan105
network 172.20.0.0
network 172.24.0.0
network 176.20.0.0
distribute-list 50 out
no auto-summary
need to investigate more.hmmm....
Istvan_Rabai Sun, 02/08/2009 - 22:55
Hi Shawkat,
You are maybe looking for the routes that are redistributed from eigrp to rip?
I should tell you that they will NOT appear in the routing table of THIS router.
These redistributed into rip routes will only appear in OTHER rip routers where THIS router advertises them (after processing them through the distribute-list 50 of course).
So the routing table process rightfully selects these routes into the routing table as eigrp routes with AD 130.
Please investigate the following:
- what are the routes learned by the rip process from any OTHER router (use "debug ip rip")
- what are the routes learned by the eigrp process from the 172.20.248.3 router (use the "show ip eigrp topology all-links")
- The same prefixes that were learned by the rip process AND the eigrp process as well should be in the routing table from the rip process, as they have AD 120.
Cheers:
Istvan
shawkatalvi Wed, 02/11/2009 - 18:44
Hi Istvan,
Thanks for your time. It's getting complicated and I can see if I continue with this approach, I will need to modify AD on few switches in between hops.
Rather is their anyway where I can modify metrics on advertising EIGRP routes through a specific interface. That way 172.20.248.3 would learn eigrp which will not be better than RIP?
Istvan_Rabai Wed, 02/11/2009 - 22:29
Hi Shawkat,
I don't know of a way of setting AD based on incoming interface.
You should look at the options of the "distance" command under the router config to see all the options there are.
Keep your config simple!
Cheers:
Istvan
