VIPs not responding to pings or HTTP
Answered Question
Feb 5th, 2009
Hello Lads,
I've viewed all the previous conversations and tried all the suggestions but this has me fooled.
I can ping, telnet, HTTP, RDP to the web-server directly but not via the VIP.
I can ping the vlan interface and alias. The ACE 4710 says the VIP state is INSERVICE.
I can find no ARP entries referring to the VIP in either the ACE or switch.
I've rebooted a number of times in case of a previously mentioned bug, but to no avail.
Any help?
access-list PERMIT-TRAFFIC line 8 extended permit ip any any
probe tcp HTTP
interval 15
passdetect interval 60
open 1
rserver host RIP1
ip address 10.50.71.151
inservice
serverfarm host SF
probe HTTP
rserver RIP1
inservice
class-map match-any CM
2 match virtual-address 10.50.71.28 255.255.255.128 tcp eq www
3 match virtual-address 10.50.71.28 255.255.255.128 tcp eq https
policy-map type loadbalance first-match LB-PM
class class-default
serverfarm SF
policy-map multi-match PM
class CM
loadbalance vip inservice
loadbalance policy LB-PM
loadbalance vip icmp-reply
interface vlan 71
ip address 10.50.71.124 255.255.255.128
alias 10.50.71.126 255.255.255.128
peer ip address 10.50.71.125 255.255.255.128
access-group input PERMIT-TRAFFIC
service-policy input PM
service-policy input L4_REMOTE-ACCESS_MATCH
no shutdown
interface vlan 75
ip address 10.50.71.252 255.255.255.128
alias 10.50.71.254 255.255.255.128
peer ip address 10.50.71.253 255.255.255.128
no shutdown
ip route 0.0.0.0 0.0.0.0 10.50.71.1
Cheers
David
Correct Answer by Gilles Dufour about 7 years 11 months ago
the vlan could have been associated with the context in the Admin context.
So, it will show even if not configured in this context.
Get us a 'show tech' from both Admin context and your context "Context".
Did you allocate enough mgmt connection ?
Try to set the minimum for all resources to 10%.
Gilles.
Overall Rating: 5 (1 ratings)
Gilles Dufour Fri, 02/06/2009 - 02:59
Upgrade to A3(2.1) and see if that makes a difference.
You should see an arp entry for the vip in the ace itself.
G.
dlongworth Sun, 02/08/2009 - 15:54
I've also reverted back to Version A1(8.0a) but still no arp entries.
dlongworth Sun, 02/08/2009 - 17:07
Also,
the show service-policy command shows Vlan 1 as well as vlan 71 but vlan 1 is not configured. What is that?
ACE/Context# sh service-policy
Policy-map : TEST-PM
Status : ACTIVE
Interface: vlan 1 71
service-policy: TEST-PM
class: CM
loadbalance:
L7 loadbalance policy: LB-PM
VIP ICMP Reply : ENABLED
VIP State: INSERVICE
curr conns : 0 , hit count : 0
dropped conns : 0
client pkt count : 0 , client byte count: 0
server pkt count : 0 , server byte count: 0
conn-rate-limit : 0 , drop-count : 0
bandwidth-rate-limit : 0 , drop-count : 0
compression:
bytes_in : 0
bytes_out : 0
Parameter-map(s):
HTTP-PERSISTENCE
Correct Answer
Gilles Dufour Sun, 02/08/2009 - 23:10
Gilles.
dlongworth Mon, 02/09/2009 - 15:03
I forward the show-tech Gilles, can I have your email address pls?
I've allocated resources but this is still on a test-bench. It's not processing anything much.
dlongworth Mon, 02/09/2009 - 17:42
Issue resolved.
The class-map config:
I thought the mask was required as a subnet mask for the VIP. Didn't realise I accidentally setup a match-class for a subnet not a host.
Removed mask and everything good.
