Path Isolation-vrf
Feb 5th, 2009
Can you please check the attachment and revert with any suggesstion.i am planning to path isolation for diffrent vlans.in the schematci vlan 10 has taken as example..access is 2960...distribution==cisco 6509 vss 720 with advanced ip services ..core ==cisco 6509 vss 720 with advanced ip services ==firewall is vrf aware....
u can add your suggession.can point out the mistakes..
shivlu jain Fri, 02/06/2009 - 07:50
  • Silver, 250 points or more
1. MSTP can be used if you want to use the both links.
2.BGP can be used with wan links and can play with attributes.
3.Core 1 & core are u planning to add any FWSM
4.For server you have shown vlan 10 which is not possible because if you use the vlan 10 and two ips for the same broadcast domain can not be used. Use one link for vlan 10 and another for vlan 20.
regards
shivlu jain
