Trunk and Access VLAN
Feb 6th, 2009
Hi NetPro,
something new to me, wish netpro can share to me and guide me how to resolve this.
Upstream Switch A- model WS-C3750G-12S-S (version 12.2(35)SE5)
Downstream Switch B - Model WS-C3560-24PS-S ( version 12.2(35)SE5)
vtp domain - jack
vtp mode - transparent.
vtp version - 2
when i configured both switch as trunk and dot1Q. it doesn't work.
so, i tried to change it to access vlan. and it work successful.
i am curious. what wrong with this ?
regards,
jack
Overall Rating: 3.1 (12 ratings)
Jack,
OK firstly VTP has nothing to do with trunk configurations, VTP is for VLAN Administration. Just for the record having the VTP mode set to Transparent - means that if the switch recevies a VTP VLAN Change/Deletion/Addition - the switch will ignore it, but pass it on.
Connecting 2 switches together using an access layer port will work, as default. As they are both acting as very intellegent HUBS when you do this.
To get both switched connected via a trunk you must check you config - as it will be wrong.
ALL you need to configure on both switch ports that you want to connect together using as a trunk is the below:-
interface <>
switchport mode trunk
no shut
HTH>
ney25 Fri, 02/06/2009 - 16:14
Hi andrew,
thanks for your information, yes i agreed with you, but i have tried the configuration which same like yours before i posting to forum, i just feel weird . how come trunk --> trunk doesnt work ? whereby acees vlan --> access vlan work successfully.
thanks.
glen.grant Fri, 02/06/2009 - 16:32
  • Purple, 4500 points or more
You should post your config. Did you create the layer 2 vlans ? Verify with show vlan . Trunk config should be like this
conf t
vlan 2
vlan 3
exit
int G1/10
switchport
switchport trunk native vlan 2
switchport trunk allowed vlan 2,3
ney25 Sun, 02/08/2009 - 05:00
Hi Glen,
thanks for your information, yeah i known this configuration, before i posted i have tried these commands as well.
that's why i said i feel something wrong and kind of weird , how come both port set as access vlan and it worked. whereby set to trunk it doesn't work.
i will try to get the switch setting and config and post it .
thanks.
regards,
jack
ney25 Sun, 02/08/2009 - 23:49
Hi Glen / Andrew.
i found out something pretty weird, for instance:
Switch A - 10.10.10.10 255.255.255.0 VLAN 1
Switch B - 10.10.10.9 255.255.255.0 VLAN 10
now then Switch A - Port 12 (Configured as trunk and dot1Q)
Switch B = Port 24 (configured as trunk and dot1Q)
when i show CDP nei. i can see each other but when come to access and ping .
it is not reachable.
so, from above statement which obviously shown that the VLAN-ID is different.that's why i was unable to reach to each other. so, when i changed the Switch B to VLAN 1. then i can reach to each other.
but, i have just curious i have some other switch which having native vlan-mismatched for months which no problem for pinging / access each other. how this switch totally can not unreachable at all ?
p/s : this 2 switch is peer to peer connecting to each other (Sw A -> Sw B)
your reply will be highly appreciated.
regards,
jack
ney25 Mon, 02/09/2009 - 01:57
Hi Andrew,
i have wr erase the entire switch.
now this 2 switches are brand new.
i have configured Switch A VLAN 1 - ip address 10.10.10.1 255.255.255.0
and Switch B VLAN 10 - ip add 10.10.10.2 255.255.255.0
and connect this 2 switch from port to port (Port 24 connected to Port 12 as trunk , Dot1Q). but still unable to reach each other. unless i changed the VLAN-ID 1 to VLAN 10 .
thanks.
Terryn Barbarich Mon, 02/09/2009 - 02:16
You can't have the same subnet across two different VLAN's (unless your not routing between the two VLAN's or configuring SVI's) 10.10.10.1/24 and 10.10.10.2/24 are the same subnet. That'll be why it starts to work when you change the VLAN to the same as the other switch. Is the link actually coming up?
sh int fa0/24?
ney25 Mon, 02/09/2009 - 02:27
Hi Terryn123,
thanks for your information, let me give you some background first.
the live switch (which done by someone) had configured wrongly, that mean Switch A - Management IP VLAN 1 - 10.10.10.1 255.255.255.0
and the uplink Switch B - Management IP VLAN 10 - 10.10.10.10 255.255.255.0
and both of these switches connected as trunk and it works fine and reachable.
and the model of switch was 3560.
now then, i have another site also got such problem. but this time the uplink switch using 3750. so, similar configuration from the above.
but, somehow this model 3750 doesn't work.
i have wr erase and reconfigured the exactly setting for testing purpose. also doesn't work. unless both trunk port changed to Access VLAN . or Change to the same Management VLAN-ID.
because, i just want to confirm is that the 3750 problem ?
thanks.
Jack,
The 3750 has the same switching/trunking capabilities as 99% of Cisco switches - if it's not working, it's because you are not configuring it right.
Just for testing purposes, as it appears you are not really understanding the concept of VLAN tagging.
Configure 2 VLANs on a switch. Add VLAN 10. So now you will have VLAN 1 and VLAN 10. Configure Fa or Gig 0/1 into vlan 1
interface >
switchport mode access
switchport access vlan 1
Configure the second port into the other vlan
interface >
switchport access vlan 10
no connect a pc to port 1 and a pc to port 2.
Give the PC's an IP address in the same range but seperate - like:
PC1 - 192.168.1.1 255.255.255.0
PC2 - 192.168.1.2 255.255.255.0
Once the ports are up/up on the switch and the PC's show they are connected try and ping each machine.
ney25 Mon, 02/09/2009 - 06:23
Hi Andrew,
i am using packet tracer to simulate the problem which i am facing right now. the output exactly like my live switch environment.
kindly find from attached file.
Jack,
Again I will say it again - it will NOT work, as the SVI (Layer 3 interfaces).
I am not familular with the packet tracer software, so I cannot comment.
If you create vlan68 in switch2 and give it the ip address "ip address 10.76.68.14 255.255.254.0" from vlan 1 and test again.
ney25 Mon, 02/09/2009 - 06:51
Hi Andrew,
yes, this will work coz, i have tested all before i posted and looking for advice.
ney25 Mon, 02/09/2009 - 06:59
hahaha, yeah that's my concern.
i also don't know what to do now, i am pretty blur . this is my first time encountered this problem.
like i mentioned to you earlier. another site which having the same config (the only different is the switch they are using 3560 ) and it was working.
now then my upstream switch is 3750 but doesnt work.
OK listen - The trunking in your sim is working. Further testing will prove this:-
1) Create more vlans on both switches, and give them IP addresses and ping between them.
2) Configure VTP on the switches - as the name suggests VLAN Trunking Protocol WILL NOT work if there is NO trunk between 2 switches.
3) If you have some switches in a production environment that are not trunking 100% CHECK THE CONFIG.
Trunking is one of the most basic, turn it on and it will work protocols in the Cisco Switch environment, if it's not working, there is a config issue or physical issue 99.99% of the time.
HTH>
Leo Laohoo Mon, 02/09/2009 - 13:22
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Just to add: Make sure "IP Routing" on the 3750 is disabled (no ip routing).
ney25 Mon, 02/09/2009 - 16:56
Hi Leolaohoo.
yes, it was disabled.
any other idea ?
thanks.
Leo Laohoo Mon, 02/09/2009 - 22:17
  • Hall of Fame,
    2017 LAN, Wireless
Can you try to post the "sh run" of the two switches?
