ASA and PIX integration ?
Answered Question
Feb 6th, 2009
Dear ALL,
as a firewalling solution I have a PIX 515E version 6.3(4) and in the near future I have to connect to a company partner, and I'd like to implement a VPN between two Cisco equipment, my PIX to my side and a new ASA 5510 by partner side. What I have to do is to share LANs like were a big one.
My question is, with my PIX and a new ASA could I implement that scenario ( I'm thinking to different equipments, different software and different commands) ?
Alberto Brivio
Alberto,
The only difference between the 2 devices is th hardware. If you wanted to, you could upgrade your PIX to the same version of IOS as the ASA - but to be honest they are fully compatible as is.
As long as the PIX has 64mbs of memory, you will be able to run the same version of IOS that the ASA will be running.
HTH>
Overall Rating: 5 (1 ratings)
Correct Answer
Alberto,
HTH>
victor_87 Fri, 02/06/2009 - 06:13
Why are you even worried about the hardware.
You can setup a L2L VPN between an ASA and a local made DSL router that has VPN capabilities. PIX does have VPN capabilities in OS v 6.3 so u can go ahead and setup a vpn. no issues.
