CCME - Transcoding g729r8 - g711
Feb 6th, 2009
Hi all. I want to configure up my remote office 7941 to use the g729 codec. My remoe office has a vpn tunnel and works fine using the g711 codec, but its too bandwidth heavy really (connecting to a 2801 ccme).
I've manually set the ephone to use the 729 codec, but I don't get any voice traffic so I assume that i need to configure transcoding somehow.
Anyone got any pointers?
THanks
Huw
Nicholas Matthews Fri, 02/06/2009 - 04:43
Hi Huw,
You should not need a transcoder for phone-to-phone calls. If the remote phone only supports g729 then the local phones should use g729 locally when the call the remote phone.
You would need a transcoder for calls to CUE however, because it only supports G.711ulaw.
hth,
nick
davieshuw Fri, 02/06/2009 - 06:09
Thanks Nick. I always thought i'd need to transcode between the two codecs as ive never successfully made a 729r8 configured phone (7941 and the IP Communicator) talk to a 711 configured phone (7941). The phone will ring but no voice traffic happens.
When I revert both codecs back to 711 the conversations work.
So does this mean that i'll have to make all the phones in head office use the 728 codec (along with all remote IP Communicator's and 7941's ) then i'll be able to make the calls?
Paolo Bevilacqua Fri, 02/06/2009 - 06:34
The thing is that is supposed to work configuring codec g729 on the remote only, without use of dspfarm, unless talking to something g711 only like CUE.
The phones on head office are supposed to be left at default and doing g729 only when the remote so requests.
Which FW you have on the 7941? Can you try other phones like ipcp ?
Nicholas Matthews Fri, 02/06/2009 - 07:00
Hi Davie,
Changing the codec shouldn't give you no-way voice. There would be something else going on there causing that problem. You can try configuring 'mtp' under the remote phones to see if this makes a difference, or upgrading IOS.
hth,
nick
davieshuw Sat, 02/07/2009 - 02:51
interestingly this only happens when I make a perfectly working remote phone use the g729 codec. As soon as I remove the relevant line i get voice traffic back.
I get the same on our UC520 too, so thats why i was thinking it was a transcoding issue.
