Meetingplace Express & outlook
I can't install outlook plugin. When I try to install appear a message tha says: "Setup encountered an error during copying the form file 0x80070003". According to Cisco the problem it with system default language. There are something to resolve this problems without change de system language.
mattcalderon Fri, 02/06/2009 - 05:13
When you download the plugin, rename it to setup.exe and then save it and run it.
