Is possible run CME in USB Flash Memory (2851 Router)
Feb 6th, 2009
Hi Guys,
Can I use the USB in a 2851 Router to run the CME 7.1 ? I have only 64 of Internal Flash and I wanna know if I can use and USB memory or I will have to upgrade the flash memory to 128MB or 256 MB.
If yes and tip or link showing how to do ?
My Best Regards
Andre Lomonaco
paolo bevilacqua Fri, 02/06/2009 - 05:05
  • Hall of Fame,
    Founding Member
Hi, sure you can use usb memory, it's just a matter of where you will keep certain files, what you want to keep, etc.
It's quite possible that you can do with 64MB, It's also a matter of IOS image size, eg ip/voice w/o crypto is quite small.
