Newbie Needs Help Please - VoIP and VPN
Feb 6th, 2009
I have a question about some voip/vpn configuration. I've got two sites that have 1760 routers with fxo/fxs cards that are going to be tieing the two phone systems together with a couple of voip trunks. These are secondary devices on the network with no data traffic or real LAN even, but addressed with a 2nd wan ip on the fa 0/0 port. The only traffic going through these routers is voice/voip.
My question is about this voip setup with vpn. First off, should I or shouldn't I, or even can I? If I configure a site-to-site vpn connection, will the voip traffic pass over that? How would I set up a VPN tunnel for only the fxo/fxs cards with no "LAN" behind it? Is there a need to have a vpn? Any benefits to sending the voip data across vpn, other than the obvious encryption of the "call"?
The thing is, I've only setup a VPN with Cisco a few couple of times, and once was from a pre-configured script I found and the other was from some software called SDM. I've only known about setting up VPN's for connecting the LAN behind router A to the LAN behind router B. This setup has NO LAN. The only interfaces are the fa 0/0 (getting static wan ip), and the fxo and fxs cards handling the voice. I have no clue on how to configure a site-to-site VPN for this, or if I even can, or if I should.
The next two replies will have my voip configuration as it sits on the bench in testing; I have both fa 0/0 interfaces connected to the local LAN just for a connection and testing, but each will later be getting it's own static WAN IP on the fa 0/0 interfaces:
sandman420 Fri, 02/06/2009 - 06:32
SITE 1:
version 12.4
hostname SITE 1
boot-start-marker
boot-end-marker
enable secret XXX
no aaa new-model
voice-card 2
voice-card 3
ip cef
interface FastEthernet0/0
ip address 192.168.254.30 255.255.255.0
speed auto
no shutdown
no ip http server
no ip http secure-server
control-plane
voice-port 2/0
connection plar opx 290
voice-port 2/1
connection plar opx 291
voice-port 2/2
voice-port 2/3
voice-port 3/0
connection plar 190
voice-port 3/1
connection plar 191
voice-port 3/2
voice-port 3/3
dial-peer voice 180 pots
destination-pattern 180
port 2/0
dial-peer voice 181 pots
destination-pattern 181
port 2/1
dial-peer voice 190 voip
destination-pattern 19
session target ipv4:192.168.254.40
line con 0
logging synchronous
line aux 0
line vty 0 4
password xxx
logging synchronous
login
transport input telnet
end
sandman420 Fri, 02/06/2009 - 06:33
AND SITE 2:
version 12.4
hostname SITE 2
boot-start-marker
boot-end-marker
enable secret XXX
no aaa new-model
voice-card 2
voice-card 3
ip cef
ip address 192.168.254.40 255.255.255.0
speed auto
no ip http server
control-plane
voice-port 2/0
connection plar opx 280
voice-port 2/1
connection plar opx 281
voice-port 2/2
voice-port 2/3
voice-port 3/0
connection plar 180
voice-port 3/1
connection plar 181
voice-port 3/2
voice-port 3/3
dial-peer voice 190 pots
destination-pattern 190
port 2/0
dial-peer voice 191 pots
destination-pattern 191
port 2/1
dial-peer voice 180 voip
session target ipv4:192.168.254.30
line con 0
logging synchronous
line aux 0
line vty 0 4
password xxx
logging synchronous
login
end
