Voice RTP not tagged in EF ?
Feb 6th, 2009
It seems that my IP Phones 7911 have their voice flow that are not tagged in EF but in DSCP 0, why ?
DSCP For Call Control CS3
DSCP For Configuration Default
DSCP For Services Default
How can I change this, I'm with a CCME.
thanks
Olivier
Nicholas Matthews Fri, 02/06/2009 - 07:28
  • Red, 2250 points or more
Where are your IP phones connected?
Is it a switch?
Does that switch have MLS qos enabled? Does the port the phone is connected to have 'mls qos trust dscp' or 'mls qos trust cos'?
-nick
ogor Fri, 02/06/2009 - 07:38
no mls qos enabled I want to specify the IP Phone to tag the RTP in EF and the sig in AF31 but on the phone not on the routers.
Temporarely I have configure policy-map to identify with ACL my RTP and Sig trafic and to tag them but I prefer to do it internally on the IP Phone (7911)
calluknet Sun, 02/08/2009 - 13:15
NM-16ESW with PPWR-DCARD-16ESW - I think this integrated switch enables mls qos by default. Default means that nothing is trusted so you do need to enable trusting as you suggest.
Paolo Bevilacqua Fri, 02/06/2009 - 07:30
  • Hall of Fame,
    Founding Member
Which exact IOS and phone FW ?
ogor Fri, 02/06/2009 - 07:36
They are connected on a NM-16ESW with PPWR-DCARD-16ESW router card.
Please check the attahed files to see the 2 type of routers used.
Olivier
calluknet Sun, 02/08/2009 - 13:12
How is the access layer switch configured? Are the phones directly connected to your lan? What type of switch/line cards are you using?
Worst case scenario can you use MQC to remark RTP?
