EPRT Request - Any thoughts or suggestions would be apprecaited.
Feb 6th, 2009
We are using an ASA 5505 in a small office LAN environment. When we try to run the update process on a postage machine (the machine connects to an ftp server to download updates) the process always times out with 0% transfered. I set a capture on the 5505 and it shows a "Request EPRT" being sent from the postage machine. The response from the server is "500 'EPRT' command not understood." The vendor, Pitney Bows, says it is a network issue, not a problem with the machine -- apparently they have never encountered this before. That is hard for me to believe, but I have to take their word for it. I tried to research EPRT and only know that it is an IPV6 command introduced to replace the PORT command. Is there anything I can do at the ASA to fix this? Any comments would be apprecaited.
-Roger
connectone Fri, 02/06/2009 - 11:28
Can turn debug on and post the log lines from the ASA.
Frank
scudderconsulting Fri, 02/06/2009 - 12:04
I did set the log level to debug but that was not helpful. That is why I turned on capture. I don't know what the best way to post the lines from the pcap format file would be. I'll try to do that when I get a few minutes.
Roger
