Stephen Rodriguez Fri, 02/06/2009 - 12:09
Sure can. Just make sure the Data is set for HREAP Local switching, and you that you map the VLAN correctly per SSID.
On a related note....if you do put the Guest as local switch to go out a local Internet connection, the WLC will still serve up the Web Auth page, and then the traffic routes local.
HTH,
Steve
stanleyworks Fri, 02/06/2009 - 12:13
Steve,
thanks for reply to my message.
I have addition question regarding to this.
on the Guest WLAN if I configure Central Auth/ Local Switching... is there option for me to add acl on this WLAN?
for example after pass auth. user only able to go internet...
thanks,
Nhan
Stephen Rodriguez Fri, 02/06/2009 - 12:19
Best place to put that ACL is on the Layer 3 interface for the network. Whether that is your Firewall, Router, or L3 enabled Switch.
