Joe Clarke Fri, 02/06/2009 - 08:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is no entry for this TCP protocol in the Protocol Directory. If you are using a custom application which uses its own TCP protocol, you might consider adding an entry for that protocol under Setup > Protocol Directory.
