Flex Links
Feb 6th, 2009
  • Bronze, 100 points or more
I am configuring FLEX LINKS in my Data Center - unless someone thinks this is a really BAD idea. (the reason is to remove spanning-tree) Our future calls for VSS but we are not ready for that now.
IOS is 12.2(33)SXI Advanced Enterprise.
My question is - can I still use vlan pruning?
Below is my data center setup.
My data center consists of multiple pairs of 6509E series switches that will act as a collapsed Access/Distribution layer.
All pairs of switches connect to the CORE via ONLY layer-3 redundant links.
IGP is EIGRP
The Access/Distribution layer pairs are joined together via two port-channels.
Port-channel 1 is 2 10-Gbps links
T1/1 and T5/5
Port-channel 2 is 4 1-Gbps links
G3/1, 4/1, G5/1 and G5/2
PC1 will be primary.
PC2 will be Secondary.
THANKS for any support.
cdusio Fri, 02/06/2009 - 15:26
Yes you can still prune. Basically flex links are a substitute for spanning tree whereas the pruning you are speaking of refers more to trunking and is a seperate issue.
-C
fsebera Fri, 02/06/2009 - 15:52
Hey,
Thanks for the reply.
I noticed before enabling Flex Links I had pruning enabled on both Layer-2 links between the two 6500-E switches.
I have vlans 2-50 configured on both switches. VTP mode Transparent, VTP ver 1.
Vlan 50 is not assigned to any port on either switch.
With Flex Links not enabled
Show interface trunk revealed vlan 50 was being pruned.
Once I enabled FLEX LINKS, I noticed vlan 50 was now allowed on the link
show interface trunk
indicates vlan 50 is now being forwarded across the primary link (backup link shows no vlans being forwarded - as expected).
Perhaps I did something incorrect or reading the output wrong???
Frank
cdusio Sat, 02/07/2009 - 04:32
put the config in here so I can see what's doing... Specifically on the 6509 with the flex links configured.
fsebera Mon, 02/09/2009 - 07:38
Hi C!
In my initial setup, I configured FLEXLINKS on both ends of the port-channel. I removed the config, I reloaded both switches, and configured FLEXLINKS on just one end, now is working as expected, I included the config for your review anyway.
Any thoughts?
A3#sh spanning-tree
VLAN0100
Spanning tree enabled protocol ieee
Root ID Priority 8192
Address 0021.56ee.dc64
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 8192
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Po1 Desg FWD 1 128.1665 P2p
Po2 Desg FWD 3 128.1666 P2p
A3#sh int trunk
Port Mode Encapsulation Status Native vlan
Po1 on 802.1q trunking 100
Po2 on 802.1q trunking 100
Port Vlans allowed on trunk
Po1 100-150
Po2 100-150
Port Vlans allowed and active in management domain
Po1 100
Po2 100
Port Vlans in spanning tree forwarding state and not pruned
Po1 100
Po2 100
A3#! SETUP FLEXLINKS BACKUP
A3(config)#int po1
A3(config-if)#switchport backup interface po2
A3(config-if)#
*Feb 9 09:29:50.673 EST: %SPANTREE-SP-6-PORTDEL_ALL_VLANS: Port-channel2 deleted from all Vlans
*Feb 9 09:29:50.677 EST: %SPANTREE-SP-6-PORTDEL_ALL_VLANS: Port-channel1 deleted from all Vlans
A3#sh run int po1
interface Port-channel1
switchport
switchport trunk native vlan 100
switchport trunk allowed vlan 100-150
switchport trunk pruning vlan 100-150
switchport mode trunk
switchport backup interface Po2
A3#sh run int po2
interface Port-channel2
switchport
A3#sh spanning-tree
No spanning tree instance exists.
A3#sh int trunk
Po1 100-150
Po2 100-150
Po1 100
Po2 100
Po1 100
Po2 none
! NOW LOOK AT LAYER-2 PEER SWITCH - in NEXT Message
fsebera Mon, 02/09/2009 - 07:39
A4#sh int trunk
Po1 100-150
Po2 100-150
Po1 100
Po2 100
Po1 100
Po2 100
A4#sh spanning-tree
VLAN0100
Root ID Priority 16384
Address 0021.56ed.bc64
Bridge ID Priority 16384
Aging Time 15
A4#sh run int po1
description A3 Primary
switchport
A4#sh run int po2
description A3 Secondary
switchport
A4#sh run int T1/1
interface TenGigabitEthernet1/1
description A3 T1/1
switchport
dampening
udld port aggressive
channel-group 1 mode on
A4#sh run int T5/5
interface TenGigabitEthernet5/5
description A3 T5/5
switchport
dampening
A4#sh run int g8/25
interface GigabitEthernet8/25
description A3 G8/25
switchport
dampening
channel-group 2 mode on
A4#sh run int g9/1
interface GigabitEthernet9/1
description A3 G9/1
switchport
dampening
Mohamed Sobair Sat, 02/07/2009 - 06:02
  • Gold, 750 points or more
What's the relation between Vlan prunning and flex-link?
Flex-link is a feature has been introduced to avoid loops in aredundant Network topology, basically configured on a redundant uplinks.
u should consider (Flex-link) when spanning-tree is not implememnted, As you know , its based on ur requirment and Network Design. The implication/limitation of Spanning-tree is the maximum diameter of 7 per STP instance. A large Scale Switching Network usually considers Flex-link instead of implementing Spanning-tree based on what described above.
Mohamed
