02-06-2009 08:53 AM - edited 03-15-2019 04:03 PM
We've been using MGCP w/D channel backhaul in the past with no problems. I'm now trying to configure a Cisco 2851 with a PRI using H.323. I can't figure out why my POTS dial peer is showing "down" on "OUT STAT".
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT
1 voip up up ....... 1 syst ipv4:10.10.10.10
2 voip up up ....... 2 syst ipv4:10.10.10.11
10 pots up up .T 0 down 1/0:23
PRI Channel Statistics:
ISDN Se1/0:23, Channel [1-24]
Configured Isdn Interface (dsl) 0
Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3
Service State (0=Inservice 1=Maint 2=Outofservice 8=MaintPend 9=OOSPend)
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface Serial1/0:23
description PRI
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
dial-peer voice 1 voip
preference 1
destination-pattern .......
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.10
incoming called-number .
dtmf-relay h245-signal h245-alphanumeric
no vad
dial-peer voice 2 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.11
no vad
dial-peer voice 10 pots
destination-pattern .T
direct-inward-dial
port 1/0:23
forward-digits all
Any help would be greatly appreciated.
02-06-2009 09:18 AM
Can you post the output of your sh isdn status and sh ip interface brief
02-06-2009 09:20 AM
XXX-2851#show isdn status serial 1/0:23
Global ISDN Switchtype = primary-4ess
ISDN Serial1/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 1
Total Allocated ISDN CCBs = 0
BOA-2851#show ip interface brief
GigabitEthernet0/0 172.26.3.1 YES NVRAM up up
GigabitEthernet0/1 172.26.4.1 YES NVRAM up up
Serial0/1/0 unassigned YES NVRAM up up
Serial0/2/0 unassigned YES NVRAM down down
Serial0/3/0 unassigned YES NVRAM up up
Serial1/0:0 unassigned YES unset down down
Serial1/0:1 unassigned YES unset down down
Serial1/0:2 unassigned YES unset down down
Serial1/0:3 unassigned YES unset down down
Serial1/0:4 unassigned YES unset down down
Serial1/0:5 unassigned YES unset down down
Serial1/0:6 unassigned YES unset down down
Serial1/0:7 unassigned YES unset down down
Serial1/0:8 unassigned YES unset down down
Serial1/0:9 unassigned YES unset down down
Serial1/0:10 unassigned YES unset down down
Serial1/0:11 unassigned YES unset down down
Serial1/0:12 unassigned YES unset down down
Serial1/0:13 unassigned YES unset down down
Serial1/0:14 unassigned YES unset down down
Serial1/0:15 unassigned YES unset down down
Serial1/0:16 unassigned YES unset down down
Serial1/0:17 unassigned YES unset down down
Serial1/0:18 unassigned YES unset down down
Serial1/0:19 unassigned YES unset down down
Serial1/0:20 unassigned YES unset down down
Serial1/0:21 unassigned YES unset down down
Serial1/0:22 unassigned YES unset down down
Serial1/0:23 unassigned YES manual up up
02-06-2009 09:22 AM
Layer 2 needs to say MULTIPLE_FRAME_ESTABLISHED. Do term mon and debug isdn q921 and see what the output is and post it.
Hope that helped, if so please rate.
