vpn default 3 login per account ?
Answered Question
Feb 6th, 2009
I use a external AD database for vpn authentication login.
I just noticed by default, asa only allow 3 simultaneous login per account. I tried to login vpn using multiple PCs with same username, but only can login with 3 PCs, as long as I tried fourth one, one of the precious 3 got disconnect..
Is any way I can increase the number?
Correct Answer by Ivan Martinon about 8 years 2 weeks ago
Yes, go into Group-policy mode and set the number to your desired setup:
group-policy WHATEVER general-atributes
vpn-simultaneous-logins X
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/uz.html#wp1572279
Overall Rating: 5 (1 ratings)
