Password on the ASA5505 console port?
Answered Question
Feb 6th, 2009
Is it possible to password the console port on a ASA5505 so anyone plugging into it doesnt even get the > prompt without supplying a password? Kind of like putting a password on "line con 0" in IOS.
I have a bunch of these 5505's I am sending out to teleworkers and I dont want them messing with it.
Also is it possible to kill the USB ports?
much thanks.
e-
Correct Answer by Collin Clark about 8 years 1 month ago
You can configure AAA locally (if you're not using a AAA server already) and use the following command to have the console port use AAA.
aaa authentication serial console LOCAL
or
aaa authentication serial console TACACS+ LOCAL (if you're using remote AAA)
I don't know of a way to disable USB, but I'll check around.
Hope that helps.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Fri, 02/06/2009 - 09:40
  • Purple, 4500 points or more
or
Hope that helps.
Eric Hansen Fri, 02/06/2009 - 09:41
it does, thanks.
any idea on those usb ports? I dont trust users to plug in whatever may fit.
Collin Clark Fri, 02/06/2009 - 11:35
I can't find anything on disabling it. You could try contacting your local SE and see if he knows. Next time I see ours , I'll try and remember to ask. You could always try electrical tape over the port!
