Telepresence equipment freight weight + measurements
Feb 6th, 2009
Hi! I'm working with a design of Telepresence installations and for import/export rates calculation I need the exact freight weight and measurements of each CTS system, that's CTS-500, CTS-1000, CTS-3000 and CTS-3200. I've read all the datasheets available but the info isn't complete nor accurate in all of them. I'd really appreciate your help.
Thanks a lot.
Paolo Bevilacqua Fri, 02/06/2009 - 10:54
Hi, the partner you're buying from should be able to give you information, as they will get it from cisco as required.
