02-06-2009 11:32 AM
i am having issues with SNMP traps for link up and link down. i run a capture and i see snmp but not snmp traps. any advice?
02-09-2009 03:19 AM
Did you enabled the traps?
Use the command snmp-server enable traps
For more infomation before you apply the command:
Look at http://cisco.com/en/US/docs/storage/san_switches/mds9000/sw/rel_3_x/command/reference/CR03_s.html#wp1283710
I hope this helps.
Best regards.
Massimiliano.
Log in to Community
