Need help adding a device to an existing vlan
Feb 6th, 2009
I need some help adding a device to an existing, recently created vlan.
Here is the fragment of our network:
[core 4507] -> [8540] -> [3550] -> [1230 WAP]
[configuration excerpts are below]
The 1230 access point described is attached to our network, and is functioning properly. Recently, I tried to add another 3550 (in another part of the building), and a 1230 access point, copying the first configuration as the model. The vlan 99 (the user workstations) worked right away, but vlan 199 (the wireless access points) I cannot get working.
I can still get to the first access point, but am having trouble with the new one:
- it's unreachable when connected to the new switch, but I can get to it when connected to the first switch
- I can get to the vlan 199 default gateway from the new switch, and can get to the first access point from the new switch, but I can't get to the new access point, even when logged into the new switch.
- If I assign an ip address to the vlan 199 interface, I can get to the new access point from the new switch, but then I can't get to the vlan's default gateway or to the first access point.
Can someone help me find where the problem is? Do I need to allow vlan 1 on the interface on the core 4507?
Thanks for your help!
--Steve
Here are configuration fragments of each:
4507 (vtp server, domain ADM_VTP):
interface GigabitEthernet1/1
description Trunk to 8540
switchport trunk allowed vlan 40,51,99,199,997,998
switchport mode trunk
switchport nonegotiate
no logging event link-status
qos trust dscp
tx-queue 3
priority high
interface Vlan199
description ADM WLAN Management
ip address 192.168.199.1 255.255.255.0
ip helper-address 10.99.20.62
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
end
8540 (vtp client, domain ADM_VTP):
interface GigabitEthernet1/0/0
description Fiber to 99-c45-clan1
no ip address
no ip redirects
no ip proxy-arp
no cdp enable
interface GigabitEthernet1/0/0.1
description Native VLAN
encapsulation dot1Q 1 native
no ip redirects
no ip proxy-arp
interface GigabitEthernet1/0/0.99
description ADM LAN Access VLAN
encapsulation dot1Q 99
no ip redirects
no ip proxy-arp
no cdp enable
bridge-group 99
interface GigabitEthernet1/0/0.199
description Admin WLAN Management
encapsulation dot1Q 199
no ip redirects
no ip proxy-arp
no cdp enable
bridge-group 199
interface GigabitEthernet1/0/0.997
description ADM IVDL
encapsulation dot1Q 997
no ip redirects
no ip proxy-arp
bridge-group 97
interface GigabitEthernet1/0/0.998
encapsulation dot1Q 998
no ip redirects
no ip proxy-arp
bridge-group 98
interface GigabitEthernet1/0/2
description Fiber to 3550
no ip address
no ip redirects
no ip proxy-arp
no cdp enable
interface GigabitEthernet1/0/2.1
no ip redirects
no ip proxy-arp
interface GigabitEthernet1/0/2.99
no ip redirects
no ip proxy-arp
no cdp enable
bridge-group 99
interface GigabitEthernet1/0/2.199
no ip redirects
no ip proxy-arp
bridge-group 199
interface GigabitEthernet1/0/2.998
no ip redirects
no ip proxy-arp
bridge-group 98
interface BVI199
ip address 192.168.199.2 255.255.255.0
end
spfister336 Fri, 02/06/2009 - 11:45
Here is the 3550 config:
3550 (vtp client, domain ADM_VTP):
interface GigabitEthernet0/1
description to 99-c85-catm1
no ip address
interface GigabitEthernet0/2
switchport mode dynamic desirable
no ip address
shutdown
interface Vlan1
no ip address
no ip route-cache
interface Vlan99
ip address 10.99.20.211 255.255.248.0
no ip route-cache
ntp broadcast client
interface Vlan199
no ip address
interface FastEthernet0/38
description to 1230 WAP
switchport access vlan 199
no ip address
no snmp trap link-status
end
glen.grant Fri, 02/06/2009 - 16:53
  • Purple, 4500 points or more
If you do a show vlan on the new switch do all the vlans show in the table and active? Did you create the layer 2 vlans on the new 3550 ? Sounds like the trunk isn't working right or the layer 2 vlans are missing. Can you specify on the 8540 which interface goes to the 4500 and which goes to the 3550 ?
spfister336 Mon, 02/09/2009 - 08:12
Yes, the layer 2 vlans were created on the 3550. The vlan 99 is set up the same way as vlan 199 and is working.
Sorry about the configs... I left out part of the 8540 config. The connections are:
1/0/0 -> goes to 4507
1/0/2 -> goes to old 3550 with working 199 vlan
0/0/0 -> goes to new 3550 with non-working 199 vlan
The config for 0/0/0 is similar to the config for 1/0/2:
interface GigabitEthernet0/0/0
description Fiber to 99-c35-sc1n1 (board room)
no ip address
no ip redirects
no ip proxy-arp
no cdp enable
interface GigabitEthernet0/0/0.1
no ip redirects
no ip proxy-arp
interface GigabitEthernet0/0/0.99
no ip redirects
no ip proxy-arp
no cdp enable
bridge-group 99
interface GigabitEthernet0/0/0.199
no ip redirects
no ip proxy-arp
bridge-group 199
interface GigabitEthernet0/0/0.998
no ip redirects
no ip proxy-arp
bridge-group 98
Let me know if there's anything else I can post. I'll clean up the configs and repost them if what I've given is too hard to follow.
Thanks again!
