OSPF Area 0 IP addressing
Answered Question
Feb 6th, 2009
Hi all,
I'm getting ready to split my single area OSPF network into a multi-area deployment. Right now all the links between my core devices are either /30 or /29 in the 10.5.0.0/24 address space. My concern is that after splitting the areas there will still be some of those address spaces outside of Area 0. Should I change the address space I use in Area 0, and if so, what would you recommend?
Correct Answer by Paolo Bevilacqua about 7 years 11 months ago
Yes. A reasonable amount of prefixes to start thinking area segmentation is perhaps around 1000, with frequent flapping and intensive SPF recalc.
Instead you have a small network, try to keep it the simple as possible.
Overall Rating: 5 (2 ratings)
Paolo Bevilacqua Fri, 02/06/2009 - 12:40
Sorry, how may prefixes you have, any issue running area 0 only ?
The idea is exactly to avoid the issues you're going toward, and you didn't even began using it.
branfarm1 Fri, 02/06/2009 - 12:59
Well, we don't have any issues running area 0 only right now. Just that any reconvergence anywhere in the WAN causes the whole thing to reconverge. I know that's the point, but I wanted to do multi-area OSPF so that our future expansion can isolate individual sites from problems in the WAN.
Right now we have 3 sites, using LAN addresses 10.20.0.0 /16, 10.100.0.0 /16, and 10.70.0.0 /16, respectively. All of the WAN interfaces at all sites are subnets of 10.50.0.0/24.
I guess my overall goal was to add multiarea ospf so each site only had to advertise one summary route. Am I wasting my time?
Correct Answer
Paolo Bevilacqua Fri, 02/06/2009 - 13:34
Paolo Bevilacqua Fri, 02/06/2009 - 13:55
In the meanwhile you can get few cheap routers for a lab and experiment what if ...
Thanks for the nice rating and good luck!
