Software Levels
Answered Question
Feb 6th, 2009
The IOS software is described as "Advanced IP Services", "Advances Enterprise Services", etc. Is there a doc that defines what the differences between these versions of IOS are?
Correct Answer by Edison Ortiz about 8 years 4 months ago
There isn't a doc as the features in the images varies among platforms but there is an engine that allows you to compare images dynamically, please see http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp and select 'compare images'.
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Fri, 02/06/2009 - 14:28
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
