Caller ID problem, 2 DID range on two seperate e1 Pri
Feb 7th, 2009
Ok, so, I found why half the office users caller ID's work and the other half's caller ID shows some other number other then their DID number. The problem is that 1/2 our DID's are on one PRI and the other 1/2 is on another PRI.
8001 - 8147 Serial 0/0/0 - MAIN Number is 8320
8148 - 8599 Serial 0/0/1 - Main Number is 8915
Above are the DID ranges on their respected PRI. It looks like no matter what happens, the calls go out Se0/0/0 and will only go out SE0/1/0 if the calls over flow. Which is very unlikely.
I have attached my config, I am hoping someone can assist me in providing a solution as it is very critical that caller ID works. Thanks in advance.
Ayodeji Okanlawon Sat, 02/07/2009 - 02:04
  • Cisco Designated VIP,
    2017 IP Telephony
I believe you can use translation profiles to achieve this. After some thinking this is what I came up with. Test it and let us know ho wit goes...
voice translation-rule 1
rule 1 /^0/ /10/
voice translation-rule 2
rule 1 /^0/ /20/
voice translation-profile DID1
translate called 1
voice translation-profile DID2
translate called 2
ephone-dn 1 dual-line
number 8005
label 55458005
description 8005- Reception
name Reception
translation-profile incoming DID1
call-forward busy 55458295
call-forward noan 55458295 timeout 20
corlist incoming InternatlCSS
ephone-dn 2 dual-line
number 8250
label 55458250
description 8250-Charles Cerminara
name Charles Cerminara
translation-profile incoming DID2
dial-peer voice 110 pots
corlist outgoing LocalPT
description first choice - local dialing
translation-profile outgoing CallingID
destination-pattern 10T
port 0/0/0:23
dial-peer voice 111 pots
description second choice - local dialing
destination-pattern 20T
port 0/0/1:23
What we are doing here is using translation rules to append 1 and 2 to the called number so that we can route them to the appriopriate POTS port.
The rule is then applied to the desired ephone-dn.Hence when a user on DN 8005 calls 0XXXXX, the translation profile on the ephone-dn appends a 1 to it and sends the call to dial-peer 110 Pots with se0/0/0 circuit and the same goes for user 8250 where the xlation profile appends a 2 and sends the call to se 0/0/1.
paolo bevilacqua Sat, 02/07/2009 - 04:05
  • Hall of Fame,
    Founding Member
It's not a difficult problem if telco can accept any DID of your using either PRIs. You may have to ask this explicitly and insist.
After you just set the two PRI in a trunk-group with hunt-scheme round-robin or least-used.
