PIX 7.0 shared secret
pax_2111
Is it possible to view the shared secrets for L2L VPNs? I remember somewhere reading that it is possible but can't find it.
cisco24x7
Level 6
Level 6
option #1 (I am reading this of memory):
1- write mem
2- show start
option #2:
copy the the running configuration to a
tftp server:
then the pre-share key will be seen in
clear-text
Easy right?
thanks. option 1 didn't work but TFTP worked.
If you are running version 7.x and above, you can also use the following command to display the pre-shared keys in clear-text:
more system:running-config
Best Regards.
