transconding
Answered Question
Feb 7th, 2009
I have a analog phone conected to a fxs port in the 2821 router(using sccp). If this analog phone call to a ip phone (local or remote), is transconding resources requiered ?.
Correct Answer by Nicholas Matthews about 8 years 3 months ago
Hi Rafael,
The FXS port is going to use DSPs no matter what, since it is an analog connection. Since these are the same DSPs that do transcoding, it's fairly equivalent to transcoding.
Depending on what codec CUCM negotiates with the gateway, the DSP will simply change what codec it is using.
This isn't something to worry about, unless your DSP resources weren't allocated correctly for high complexity codecs.
You can use the DSP calculator to be sure:
http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl')">http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
hth,
nick
Overall Rating: 5 (3 ratings)
Chris Deren Sat, 02/07/2009 - 10:49
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
No it is not as the GW can negotiate any codec.
Chris
Jaime Valencia Sat, 02/07/2009 - 10:58
  • Cisco Employee,
  • Hall of Fame,
    2011
what codec have you configured each device to talk?????
if G711 there is no need
java
if this helps, please rate
Correct Answer
Nicholas Matthews Sat, 02/07/2009 - 12:59
  • Red, 2250 points or more
Hi Rafael,
hth,
nick
