dynamic dns with a pc behind the asa?? for IPSC vpn
Feb 7th, 2009
can anyone suggest how can i configure such a scenario.and hows the stability?? can anyone comment
i will rate all the posts.
Binoy
binoyjosephstanly Sun, 02/08/2009 - 06:01
i want to configure ipsec vpn so that my branch people 1 or 2 users max. can connect to H.O
Binoy
binoyjosephstanly Sun, 02/08/2009 - 10:43
i need remote client vpn.i'll explain my scenario. i have one 4mbps ADSL connection at H.O, that is the only available internet connection. so i dont have a static public ip address.
now my question is how can i configure an asa 5510 for ipsec vpn using dyndns.
binoy
OK - so the easiest way I know is to have a PC on the inside, connecting to a DDNS provider updating with the source IP address of the outside ASA IP, when you don't have a static IP.
So you need a DDNS account and a domain name for the DDNS (DynDNS.com or no-ip.com). Once you have that - you just need to configure the Remote VPN to use the domain name - nice and simple.
HTH>
