Resource Class issue
Feb 7th, 2009
I am using ACE4710 with all the servers in default admin context. Now i need to enable sticky persistence and for this it asks me for resource allocation. I've couple of questions regarding this:
1- can i allocat sticky resources to default resource class?
2- If i've to create a new resource class, then how can i associate this class to default Admin context? and will Admin context be member of both default resource calss and the new resource class the same time?
3-Does it really require a restart of ACE once we change default resource class?
besides this i'd really appreciate any other recommendations/suggestions from you guys.
Syed Iftekhar Ahmed Sun, 02/08/2009 - 15:28
  • Blue, 1500 points or more
You need something like the following
resource-class mycompany
limit-resource all minimum 0.00 maximum unlimited
limit-resource sticky minimum 2.00 maximum equal-to-min
context Admin
allocate-interface vlan x
member mycompany
1. No ,you cannot edit default class. You will have to create a seperate resource class
2.Define it under "context Admin". No Admin context will just be member of the defined resource class
3.No
Syed Iftekhar Ahmed
