Cisco ASA 5510 and SNMP polling
Feb 8th, 2009
Hi all,
I've a problem to get OID values from an ASA 5510.
If i try to get the IfInOctects with a frequency of one second, for example, the values does not change. If i try to get the value with a frequency of 5 sec all seems ok.
There are limitation on the frequency that i can use to retrieve the OID values? There is some parameter which need to be configured?
