SPA-2x1GE-V2 card on Cisco XR12010
Feb 8th, 2009
I have a SPA-2x1GE-V2 card installed on a XR 12010 router which has both Copper and Fibre connectivity options but somehow, the link does not comes up on copper. When the same connection is made through on a different box (48-port-Ethernet line card)using the same cable, the link comes up. What could be the problem ?
Speed and Duplex settings of both devices are similar
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 02/09/2009 - 03:03
Hello Amit,
you probably need to specify that the RJ-45 media type has to be used:
something like
int gix/y
media-type rj-45
The default can be to use the fiber.
Hope to help
Giuseppe
