L2 VPLS 7206VXR
mugahid-mustafa
I am configuring 7206VXR (IOS 12.4(11)T); as the following:
7206(config)#l2 vfi VPLS-Test ?
point-to-point Point-to-point configuration mode
for l2 vpls there is only one option p-to-p, i can't find manual option on this IOS!! do i need to change this ios or what?
The command should be like this #l2 vfi VPLS-Test manual. Becuase using p-to-p option i can configure only 2 peers.
Any work around?
shivlu jain
Level 5
Level 5
Mustafa
7206 doesnot support VPLS. For VPLS configuration minimum requirement is 7600 with sip/spa card. On 7206 you can configure only point to point l2 circuits.
If would be better to create a psudowire and bind it to some interface.
regards
shivlu jain
