CUCMBE - MCS7816
Answered Question
Feb 8th, 2009
Hi all,
From the data sheet, the MCS7816 has dual-port Gigabit Ethernet controller embedded. So I am wondering, can both Gigabit Ethernet port be used (to do a Network Teaming) for redundancy purpose.
Thanks.
Correct Answer by Rob Huffman about 8 years 4 months ago
Hi Boon,
NIC Teaming Support
Server platforms with dual Ethernet network interface cards (NICs) can support NIC teaming for network fault tolerance with Cisco Unified Communications Manager. Cisco began support of NIC teaming on HP servers in the 5.0(1) release and began support on IBM servers in the 6.1(2) release. This feature allows a server to be connected to the Ethernet via two NICs and, hence, two cables. NIC teaming prevents network downtime by transferring the workload from the failed port to the working port. NIC teaming cannot be used for load balancing or increasing the interface speed.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp412614
Hope this helps!
Rob
Overall Rating: 4 (1 ratings)
Correct Answer
Rob Huffman Sun, 02/08/2009 - 20:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Boon,
NIC Teaming Support
Hope this helps!
Rob
boonchin.ng Sun, 02/08/2009 - 21:16
Hi Rob,
Thanks for the information. I saw this on CallManager 7 SRND as well.
Meaning to say, I am now able to configure the NIC teaming on HP/IBM MCS Server using the following command:
"set network failover enable"
Thanks.
