Change IPS to IDS
Feb 8th, 2009
Hi All,
I have an IPS Sensor 4240 working inline with the default settings... I need to do some tests and I need to change it to behave as an IDS. I know that I should configure the port on the swith as a SPAN port to send all traffic to the IDS (that will no longer be inline)....
My question is... what do I need to do in the IPS Sensor to change it to IDS?
Thank you all!
rhermes Mon, 02/09/2009 - 11:32
  • Gold, 750 points or more
The 4240 has 4 ports. One (in-line VLAN pairs) or two (in-line interface pairs) of those ports are being used. If you have a free port, put it in promiscious mode (default) and connect it to a new port on the switch that is aggregating your traffic. Configure the new switch interface as a span destination port. then disconnect your in-line interfaces (restoring traffic via another path of course).
