Leased Line connection
soumik1979
Dear All , I want some network design and configuration help from you.
1)Our main office has LAN Ip 192.168.0.0/24 and we are going to connect another branch office with IP 192.168.0.3/24 by 2 mbps leased line and 1841 cisco router with WIC2T card.Can anybody provide me the configuration of router for the same.Any Routing protocol will do.
2)In main office I have one 2000 Server as active directory.Is it possible to connect the users(XP) in the branch office to the main office active directory. If yes how???
Secondly
10 Replies 10
Giuseppe Larosa
Hello Soumik,
1)
if HQ has 192.168.0.0/24 branch can use 192.168.3.0/24.
if you have a leased line between the two sites you need a serial interface on both sides
see
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a00800b0859.shtml
the routing protocol can be eigrp
suppose you use 192.168.254.0/30 on the serial line
router eigrp 100
network 192.168.0.0
netwotk 192.168.254.0
no auto-summary
on branch
router eigrp 100
no auto-summary
network 192.168.254.0
network 192.168.3.0
note: EIGRP AS number must be the same
2) depending on how the users contact the AD you may need:
nothing if they use the AD ip address
an ip helper-address AD-ip-address
on branch router lan interface if they try to contact it via a broadcast
I think they should contact it by IP once they know how to reach it
you need for sure
ip helper-address dns-server-ip-address
Hope to help
Giuseppe
Dear Sir
Thanks for your responce
Just one thing I would like to confirm that since this is only a point to point link, can I use static route instead of Dynamic routing.
Another thing I would like to confirm.We have a 1048 Kbps Iternet leased line at main office.It connects to a cisco 1841 router and then Cisco ASA 5510 firewall and from firewall it is distributed to our LAN.I want that the branch office internet access to be done through our head office internet.Can you help me regarding that...
Hello Soumik,
you can use static routing
branch
ip route 0.0.0.0 0.0.0.0 192.168.254.1
HQ
ip route 192.168.3.0 255.255.255.0 192.168.254.2
about accessing the internet:
you need to modify the NAT statements so that also subnet 192.168.3.0/24 will be translated to access the internet.
the ASA will need a static route pointing to HQ router to reach subnet 192.168.3.0/24.
It's not clear where NAT is performed I guess on ASA but I may be wrong.
if not ASA it is made on the router with the internet link that can need a similar static route to know how to reach subnet 192.168.3.0/24
I would use EIGRP anyway because multiple devices are involved in the HQ site.
Hope to help
Giuseppe
Now we are also going to connect a new branch which is within 100 meters of the main office.I have planned fibre connectivity and the LAN IP 192.168.4.0/255.Can you help me regarding this.
Hello Soumik,
the configuration is very similar, the only differences are on the physical layer but it is even simpler
the new subnet will be 192.168.4.0/24
you may need to use a media converter from fiber to RJ-45 or you can connect the fiber to a LAN switch (better)
Hope to help
Giuseppe
At present we dont have any VLAN at our main office.The main office has LAN IP 192.168.0.0/24.The new branch will have the IP 192.168.4.0/24.So I think we need to implement VLAN for this purpose.Please advice..
Hello Soumik,
yes you need a LAN switch to be able to handle two or more Vlans.
Technically you have a single VLAN / broadcast domain at your main office.
Moving to multiple Vlans is now a standard step.
Hope to help
Giuseppe
Can you please tell me what switch is to use at main office and what to use at branch office.We are also planning to connect another office by leased line.How how things can be done.Can you give a outline for the same...
paolo bevilacqua
Hi, you mentioned two network addresses that are the same. It is not possible to do that, the network adddress must be different.
Also, since clearly you are not a networking person, I suggest you hire a reputable technincian for the job, that will save you much time and mistakes.
Sorry, I made a mistake here.The IP will be 192.168.0.0/24 and 192.168.3.0/24
