Unity configuration
Feb 9th, 2009
Hi All,
We have a running setup on Cisco Call Manager Express along with Unity module plugged into same router.
Now,the customer has purchased separate MCS hardware for Pub & Subscriber.CCM would be implemented on CCM while Unity configuration will remain on earlier CME router.
I had a concern what all we need to configure on CCM so that Unity module on router can be integrated with CCM.
regs,
aman
Overall Rating: 3 (2 ratings)
Rob Huffman Mon, 02/09/2009 - 05:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Aman,
One main thing you will need is a new license to work with CCM;
Say your system came with a License like this for CME (Note the CME at the end of the part#);
Cisco Unified Communications Manager Express
12-mailbox package: SCUE-LIC-12CME=
What you will need is a License like this for CCM (Note the CCM at the end of the part#);
12-mailbox package: SCUE-LIC-12CCM=
You can download this license file here;
http://www.cisco.com/cgi-bin/tablebuild.pl/cue-netmodule
From this good doc;
Upgrading or Downgrading the Cisco Unity Express License in the Same Version
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/installation/guide_/upglic32.html
Here is the new config guide;
CallManager for Cisco Unity Express Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
Hope this helps!
Rob
amansoi_5 Wed, 02/18/2009 - 04:48
Hi rob,
thanks for the URLs.We will do it & get back to you in case of issues.
regds,
aman
