QOS
Feb 9th, 2009
Hi ALL,
I have this configuration in global mode
priority-list 1 protocol ip high list 190
priority-list 1 interface GigabitEthernet1/1 high
and this configuration on interface
interface GigabitEthernet1/3
dampening
ip address x.x.x.x x.x.x.x
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip policy route-map RMR-VPN
speed 100
duplex full
Dont i have to use policy group command on the interface to apply the PQ configuration.
more over my Queuing method on the interface is showing as FIFO.
Chao
Vishwa
Paolo Bevilacqua Mon, 02/09/2009 - 03:02
Hi, such configuration on Gigabit makes no sense, since the interface is so fast it never sees congestion, consequently no QoS can be applied.
Beside that, the ip priority old mechanism is not compatible with modular QoS.
Please clarify what problem are you trying to solve.
vishwancc Mon, 02/09/2009 - 03:07
Hi ,
I am facing problem with voice traffic any trying to implement qos for voice.
Chao
Vishwa
Paolo Bevilacqua Mon, 02/09/2009 - 03:12
You need to implement QoS on the device facing the WAN circuit. If you can't do that, you need to explain your topology in full detail.
In any case since clearly you're not a networking person I suggest you hire a reputable professional to save you time and frustration.
Mohamed Sobair Mon, 02/09/2009 - 05:54
You should add an ACL permiting specific traffic to be used by High priority Queue.
You should also change The Priority Queue Interface to be G1/3.
Mohamed
vishwancc Tue, 02/10/2009 - 20:09
Hi Mohamed,
If i am using
along with access-list 190
do i need priority-list 1 interface gi1/3
i guess not.
