TACACS not working - Need help
dipumj
I have implemented the TACACS in VPN VRF environment but the same is not working, I am not able to route the ACS servers IP's through the VRF-VPN.
Configuration pasted below
aaa authentication login default group tacacs+ line
aaa authentication login no_tacacs line
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 0 default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
ip tacacs source-interface VLAN1
tacacs-server host X.X.X.X
tacacs-server host 10.10.10.4
tacacs-server key 7 ####################333
tacacs-server administration
aaa group server tacacs+ tacacs1
server-private 10.10.10.4 key ############
ip vrf forwarding LAN
5 Replies 5
Ivan Martinon
Level 7
Level 7
I believe there is a known issue with this setup and you might need to enter into server mode and then define the vrf forwarding interface something like this:
aaa group server tacacs+ TEST
server X.X.X.X
Thanks you so much for your mail,
I have tried with this but still I am not able make it success
server 10.10.10.14
server 10.10.10.45
ip tacacs source-interface Vlan1
It showing authorisation failed when I try a new VTY session.
You might need to get some debugs on this box as well as the failed logs from your TACACS server.
Hi sorry for late reply.
Please find below the logs from the router
Feb 12 14:10:28.748: AAA/ACCT/CMD(000000B9): free_rec, count 2
Feb 12 14:10:28.748: AAA/ACCT/CMD(000000B9): Setting session id 283 : db=846968EC
Feb 12 14:10:28.748: AAA/ACCT(000000B9): Accouting method=tacacs+ (TACACS+)
Feb 12 14:10:35.450: AAA/BIND(000000BA): Bind i/f
Feb 12 14:10:35.450: AAA/ACCT/EVENT/(000000BA): CALL START
Feb 12 14:10:35.450: Getting session id for NET(000000BA) : db=83E3E3B0
Feb 12 14:10:35.450: AAA/ACCT(00000000): add node, session 284
Feb 12 14:10:35.450: AAA/ACCT/NET(000000BA): add, count 1
Feb 12 14:10:35.450: Getting session id for NONE(000000BA) : db=83E3E3B0
Feb 12 14:10:36.014: AAA/AUTHEN/LOGIN (000000BA): Pick method list 'default'
Feb 12 14:10:38.749: AAA/ACCT/CMD(000000B9): STOP protocol reply FAIL
Feb 12 14:10:38.749: AAA/ACCT(000000B9): Accouting method=NOT_SET
Feb 12 14:10:38.749: AAA/ACCT(000000B9): Send STOP accounting notification to EM successfully
Feb 12 14:10:38.749: AAA/ACCT/CMD(000000B9): Tried all the methods, osr 0
Feb 12 14:10:38.749: AAA/ACCT/CMD(000000B9) Record not present
Feb 12 14:10:38.749: AAA/ACCT/CMD(000000B9) reccnt 2, csr FALSE, osr 0
Feb 12 14:10:46.011: AAA/AUTHEN/LINE(000000BA): GET_PASSWORD
Feb 12 14:11:14.326: AAA/AUTHOR: config command authorization not enabled
Feb 12 14:11:14.326: AAA/ACCT/CMD(000000B9): Pick method list 'default'
Feb 12 14:11:14.326: AAA/ACCT/SETMLIST(000000B9): Handle 0, mlist 83E2FF8C, Name default
Feb 12 14:11:14.330: Getting session id for CMD(000000B9) : db=846968EC
Feb 12 14:11:14.330: AAA/ACCT/CMD(000000B9): add, count 3
Feb 12 14:11:14.330: AAA/ACCT/EVENT/(000000B9): COMMAND
Feb 12 14:11:14.330: AAA/ACCT/CMD(000000B9): Queueing record is COMMAND osr 1
Feb 12 14:11:14.330: AAA/ACCT/CMD(000000B9): free_rec, count 2
Feb 12 14:11:14.330: AAA/ACCT/CMD(000000B9): Setting session id 285 : db=846968EC
Feb 12 14:11:14.330: AAA/ACCT(000000B9): Accouting method=tacacs+ (TACACS+)
Feb 12 14:11:16.642: AAA/ACCT/EXEC(000000BA): Pick method list 'default'
Feb 12 14:11:16.642: AAA/ACCT/SETMLIST(000000BA): Handle 0, mlist 83E2FEEC, Name default
Feb 12 14:11:16.642: Getting session id for EXEC(000000BA) : db=83E3E3B0
Feb 12 14:11:16.642: AAA/ACCT(000000BA): add common node to avl failed
Feb 12 14:11:16.642: AAA/ACCT/EXEC(000000BA): add, count 2
Feb 12 14:11:16.642: AAA/ACCT/EVENT/(000000BA): EXEC DOWN
Feb 12 14:11:16.642: AAA/ACCT/EXEC(000000BA): Accounting record not sent
Feb 12 14:11:16.642: AAA/ACCT/EXEC(000000BA): free_rec, count 1
Feb 12 14:11:16.642: AAA/ACCT/EXEC(000000BA) reccnt 1, csr FALSE, osr 0
Feb 12 14:11:18.425: AAA/AUTHOR: config command authorization not enabled
Feb 12 14:11:18.425: AAA/ACCT/243(000000B9): Pick method list 'default'
Feb 12 14:11:18.425: AAA/ACCT/SETMLIST(000000B9): Handle 0, mlist 83144FF8, Name default
Feb 12 14:11:18.425: Getting session id for CMD(000000B9) : db=846968EC
Feb 12 14:11:18.425: AAA/ACCT/CMD(000000B9): add, count 3
Feb 12 14:11:18.425: AAA/ACCT/EVENT/(000000B9): COMMAND
Feb 12 14:11:18.425: AAA/ACCT/CMD(000000B9): Queueing record is COMMAND osr 2
Feb 12 14:11:18.425: AAA/ACCT/CMD(000000B9): free_rec, count 2
Feb 12 14:11:18.425: AAA/ACCT/CMD(000000B9): Setting session id 286 : db=846968EC
Feb 12 14:11:18.429: AAA/ACCT(000000B9): Accouting method=tacacs+ (TACACS+)
Feb 12 14:11:18.649: AAA/ACCT/EVENT/(000000BA): CALL STOP
Feb 12 14:11:18.649: AAA/ACCT/CALL STOP(000000BA): Sending stop requests
Feb 12 14:11:18.649: AAA/ACCT(000000BA): Send all stops
Feb 12 14:11:18.649: AAA/ACCT/NET(000000BA): STOP
Feb 12 14:11:18.649: AAA/ACCT/NET(000000BA): Method list not found
Feb 12 14:11:18.649: AAA/ACCT(000000BA): del node, session 284
Feb 12 14:11:18.649: AAA/ACCT/NET(000000BA): free_rec, count 0
Feb 12 14:11:18.649: AAA/ACCT/NET(000000BA) reccnt 0, csr TRUE, osr 0
Feb 12 14:11:18.649: AAA/ACCT/NET(000000BA): Last rec in db, intf not enqueued
smak74
aaa authentication login default group tacacs1 line
aaa authorization exec default group tacacs1 if-authenticated
aaa authorization commands 0 default group tacacs1 if-authenticated
aaa authorization commands 1 default group tacacs1 if-authenticated
aaa authorization commands 15 default group tacacs1 if-authenticated
aaa accounting exec default start-stop group tacacs1
aaa accounting commands 0 default start-stop group tacacs1
aaa accounting commands 1 default start-stop group tacacs1
aaa accounting commands 15 default start-stop group tacacs1
aaa accounting network default start-stop group tacacs1
Remove the config below:
