ravpn problem
Answered Question
Feb 9th, 2009
I have created a ravpn on tha ASA 8.0(4)(resently upgraded).
The clients can connect fine but they cannot ping the inside network of the asa.
I have included the the vpn pool on the no nat access-list.
What i observed was that when i ping from the asa the raclients, it is successful!!!!
After I do so then everything seems to work fine!! Isn't it strange?
Correct Answer by JORGE RODRIGUEZ about 8 years 5 months ago
Michalis, glad it worked, could you PLS rate post as resolved.
B.Regards
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Mon, 02/09/2009 - 08:31
  • Green, 3000 points or more
Michalis,
make sure you have in asa nat-t enable as this is one of the most common symptoms from what you are describing.
asa(config)#crypto isakmp nat-traversal 20
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml#Solution1
if you do already have this statement PLS post sanitized ASA config .
PLS rate any helpful posts
michalis1234 Mon, 02/09/2009 - 12:03
Great it was that command!!!!!!
Thanks a lot man!!!
Problem solved!!!
Correct Answer
JORGE RODRIGUEZ Mon, 02/09/2009 - 12:55
B.Regards
