H323 failover
Feb 9th, 2009
We have three H323 gateways configured in CUCM 6.1.2. The 1st and 2nd one are GSM gateways and the 3rd one is the Cisco voice router, 2821 with 1 E1 line. The problem we are encountering is that when the 1st GSM gateway is busy, calls are not hunting to the next gateway. Similarly when the voice gayeway is down, calls are not hunting to the GSM gateways. We have properly configured the route groups and route list. Is there any other parameter we should configure in the CUCM? Has anyone come to a similar problem?
Chandrasen
Overall Rating: 4 (1 ratings)
Jaime Valencia Mon, 02/09/2009 - 07:42
  • Cisco Employee,
  • Hall of Fame,
    2011
actually is has been asked MANY times before, you can use the Search NetPro to find the answers
Clusterwide Parameters (Route Plan)
Stop Routing on Unallocated Number Flag = False
Stop Routing on User Busy Flag = Flag
java
if this helps, please rate
cg100668 Mon, 02/09/2009 - 07:46
Hi Java,
Thanks for the reply. In fact I saw it after I posted my question. I will give a try and let you know. Thanks again.
Chandrasen
