configuring pppoe in cisco CLI (VPDN or bba-group)???
Answered Question
Feb 9th, 2009
Hi All,
My scenario is like below:
Cisco 1841 or 2811 router -- DSL modem --- Aggregation router.
Cisco 1841 or 2811 should initiate a PPPOE to the Aggregation router.
When I started configuring PPPoE, i am not able to find the "protocol pppoe" option under vpdn group. (though on Cisco's FN pppoe-client support is listed on the IOS)
LAB-CE2-1841(config)#vpdn-group 1
LAB-CE2-1841(config-vpdn)#pro
LAB-CE2-1841(config-vpdn)#pro?
% Unrecognized command
LAB-CE2-1841(config-vpdn)#reque
LAB-CE2-1841(config-vpdn)#request-diali
LAB-CE2-1841(config-vpdn)#request-dialin
LAB-CE2-1841(config-vpdn-req-in)#pro
LAB-CE2-1841(config-vpdn-req-in)#protocol ?
l2f Use L2F
l2tp Use L2TP
This above router should initiate a PPPoE to the Aggregation router.
Just came across about the "bba-group pppoe" config CLI. Would like to know currently PPPoE under VPDN is replaced with bba-group CLI.
Or bba-group CLI should only be used on the aggregator side.
Any help is much appreciated.
thanks
Arun Kumar
Correct Answer by Giuseppe Larosa about 8 years 1 week ago
Hello Arun,
there was a change and newer IOS versions simply don't need to configure VPDN to support PPPoE client
you need just to configure under fe port
int fe0/0
pppoe-client dial-pool-number 1
int dialer
interface Dialer1
ip address negotiated
ip mtu 1492
bba-group is needed if you want to use more then one PPPoE session
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Mon, 02/09/2009 - 07:26
Hello Arun,
int fe0/0
int dialer
interface Dialer1
ip mtu 1492
Hope to help
Giuseppe
arun kumar Tue, 02/10/2009 - 21:40
Hi Giuseppe,
Thanks for your valuable help. It is working.
thanks
Arun Kumar
