Track AAR Usage in CDR records
Feb 9th, 2009
Is there any way to track in CDR records the usage of AAR. whereas I can run a report to show usage of AAR?
I recently set up a client with AAR and they are asking if there is a way to see how many calls are using AAR versus calls staying On Net within the cluster.
Chuck
Chuck Reid Mon, 02/09/2009 - 08:33
I have found that there is a redirect reason code field in a CDR. A value of 129 is used for AAR but I see no way to search for CDR's by redirect reason codes. Any Ideas?
Chuck
