Vonage or Time Warner Cable?
crowell33
I'm looking at going with either Vonage or Time Warner Cable for my home phone. Does anyone have a recommendation for to which to go with for a UC520? Will it work with either or both? Thanks for the advice.
Are you trying to use the UC500 as a replacement for the ATA thet you get from these phone providers? If that is the case, you will have to resort to CLI configuration to make them work and also make sure these providers accept a CPE other than the one they ship. CCA does to offer native support for neither.
Hope this helps,
Marcos
Hi Marcos,
To be perfectly honest, I don't know yet.:)
Whichever way is easier and/or possible.
It is possible to integrate the UC500 with Vonage, but I would advise that you talk to them. They will likely have an integration guide that should facilitate the configuration.
Good luck.
Marcos
