Doubt about CDR
Feb 9th, 2009
Hi Guys,
My Customer is using CCM version 5.1 and have the following doubt: It's possibility configure CDR to show that FAC or there are any field in CDR that show the FAC?
Wilson Santana
wilsonsant Mon, 02/09/2009 - 10:28
Hi Javalenc,]
I am sorry, but, the CDR don't have this feature?
Wilson Santana
Jaime Valencia Mon, 02/09/2009 - 10:32
let's clear something out.
CDR and CAR were different DBs in windows versions.
in linux versions there is only one DB, CAR.
there is no separate CDR database, you can get the info from the DB or use an external billing application for CDRs to process the flat files
java
if this helps, please rate
wilsonsant Mon, 02/09/2009 - 10:38
Hi Javalenc,
In this case my Customer will need configure the CAR to can see the FAC? Because, He work version 5.1 (linux)
Wilson Santana
Jaime Valencia Mon, 02/09/2009 - 10:48
yes, or as i mentioned configure a 3rd party billing server
java
wilsonsant Tue, 02/10/2009 - 09:08
Hi Javalenc,
It's possible inform to me in which field in the CAR I can found the FAC?
Wilson Santana
wilsonsant Tue, 02/17/2009 - 11:48
Hi Javalenc,
I found the docummentation that inform that is possible configure FAC in CDR. I am attached the files.
Wilson Santana
