Ip routing performance C3750E
Feb 9th, 2009
We would like the performance of 3750E forwarding IP routed packets. We know that it supports CEF and its forwarding-rate (a switching data) is 64Mpps for 64-bytes packet. But could it forward 250Mbps using IP routing?. Is there any document to know the performance of the device when it is used as a router?
Joseph W. Doherty Mon, 02/09/2009 - 09:34
Assuming hardware L3 forwarding, believe the forwarding rate is the same for L2/L3.
"But could it forward 250Mbps using IP routing?. "
Should be able to, 250 Mbps is very, very light for this class of switch since it offers about line rate to all ports. (The non-E series should easily handle 250 Mbps too.)
3750-E Performance
• 160-Gbps switching fabric capacity
• Stack-forwarding rate of 95 Mpps for 64-byte packets
• Forwarding rate:
• 3750E-24TD-65.5 Mpps
• 3750E-24PD-65.5 Mpps
• 3750E-48TD-101.2 Mpps
• 3750E-48PD-101.2 Mpps
• 3750E-48PD-F-101.2 Mpps
