02-09-2009 09:22 AM - edited 03-06-2019 03:56 AM
I have several 6500's with sup2-2GE with MSFC2. they currently are running hybrid CatOS and IOS. I want to convert to just IOS. In order to do that I need to increase the memory from 32MB flash to 64MB flash. If I use a PCMCIA card in the slot with the new IOS, can I boot the IOS from the PCMCIA card?
Solved! Go to Solution.
02-09-2009 12:55 PM
You would have to look at the release notes of the IOS code version you want to run to see what the minimum requirements are.
02-09-2009 09:39 AM
Yes you should be able as long as you point your boot statement there . Follow the upgrade instructions for catos conversion to the letter.
02-09-2009 11:37 AM
the current switches are running 32MB of Flash and 128MB of DRAM. I know the PC card will cover the Flash, but will I need to upgrade the DRAM also?
02-09-2009 12:55 PM
02-17-2009 08:55 AM
the min dram is 256M, I have 128M, so I'll have to upgrade. But there is dram on the sup card and the msfc2 card. Do I have to upgrade the dram on both?
02-17-2009 10:08 AM
I would check availability it appears the Sup 2 is EOL at this point.
02-17-2009 10:56 AM
Yes, you need upgrade both.
The following link will give you more info.
The last Q&A is about Sup2 and MSFC2.
https://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/qa_c67_457347.html
