Caller ID Masking on CUCM 6.1
Feb 9th, 2009
  • Silver, 250 points or more
All,
I am looking for a couple different solutions. I am familiar with setting up my outbound PSTN calls for Caller ID.
What I am looking to do changing the Caller ID/Display info when calling internal.
For example, when I call a store I do not want them to have the ability to call me back just because they see my number or can get it from the directory. I want them to see our support number.
For example:
My number is 867410
When I call a store I do not want them to see 867410, I want them to see 865000
I changed the Display (Internal Caller ID) but it also still shows my number in () so now the call says
865000 then under it
(867410)
Is there a way to set it up so that number does not show under it?
Or is there a better way to set this up? This is not going to be system wide either. It will be done on a group by group basis...also our CEO does not want his number to be seen either.
