CSA post-upgrade operations
Feb 9th, 2009
Hi, after the CSA upgrade I have some old kits to delete and some new kits to create for the actual groups.
I'd like to know all the post-upgrade operations necessary
thanks in advance
tsteger1 Mon, 02/09/2009 - 10:21
Do you have custom kits, policies, modules and groups?
The default new kits should already be associated with the new groups.
Any default modules and policies should have been upgraded to the new version.
Any custom modules and policies will have to be upgraded manually.
r.spiandorello Mon, 02/09/2009 - 23:50
Yes, I have some cloned modules.
When you talk about "upgraded manually" you mean "create the new kit" ?
tsteger1 Tue, 02/10/2009 - 13:51
If you look at the agent kits, there should be some with the previous version and some with the new version.
You can create custom kits to suit your environment.
By "upgraded manually", I mean any custom rules, policies, etc that did not get upgraded automatically.
You'll need to go through those and make sure they still apply to your hosts.
