Cisco 9513 Config question
Feb 9th, 2009
I currently have a Cisco 9513 that I want to lock down the SNMP-server to a select amount of snmp servers that will be accessing the 9513. On any other Cisco device I can apply an access list to the community string and lock it down but I do not seem to have that option on the 9513. Is there any way to accomplish this on the snmp-server itself or do I have to create an access-list on the management interface and go that route?
sbilgi Wed, 02/18/2009 - 07:39
Supported on the Cisco MDS 18/4-port Multiservice Module, encrypts data at rest on heterogeneous tape drives and virtual tape libraries (VTLs) in a SAN environment using secure IEEE standard Advanced Encryption Standard (AES) 256-bit algorithms. Cisco MDS 9000 18/4-Port Multiservice Module helps ensure ease of deployment, scalability, and high availability by using innovative technology to transparently offer Cisco SME capabilities to any device connected to the fabric without the need for reconfiguration or rewiring. Cisco SME provisioning is integrated into the Cisco Fabric Manager; no additional software is required. Cisco SME key management can be provided by either the Cisco Key Management Center (KMC) or with RSA Key Manager for the Datacenter from RSA, the security division of EMC.
Also follow the RFC 2461 and 2462 IPv6 neighbor discovery and stateless autoconfiguration for configuration .
Trending Topics: Storage Networking
