BGP Prefix problem
Answered Question
Feb 9th, 2009
I have what I think is a simple problem:
I have BGP setup between a couple of providers. The provider support blackhole announcements (block traffic to one of my IPs when I announce it to them via BGP using a specific community).
I currently have a /18 that I have the following configuration for:
router bgp XXX1
network XXX.XXX.XXX.XXX mask 255.255.192.0
neighbor yyy.yyy.yyy.yyy route-map PROVIDER-TRANSIT-INBOUND out
ip route XXX.XXX.XXX.XXX 255.255.192.0 null0
ip prefix-list ISP-BlackedHole seq 1 permit ZZZ.ZZZ.ZZZ.ZZZ/32
ip prefix-list ISP-BlackedHole seq 100 deny 0.0.0.0/0 le 32
ip prefix-list Transit-00 seq 20 permit XXX.XXX.XXX.XXX/18
route-map PROVIDER-TRANSIT-INBOUND permit 10
match ip address prefix-list ISP-BlackedHole
set community XXXX:YYYY
route-map PROVIDER-TRANSIT-INBOUND permit 20
match ip address prefix-list Transit-00
The intent is to send the IP that is under attack (in this case ZZZ.ZZZ.ZZZ.ZZZ) to the provider via BGP tagged with their community.
After reseting the peering, I noticed that only the /18 was being sent out. When I do a "show ip bgp prefix ISP-BlackHole", nothing was returned. For some reason ZZZ.ZZZ.ZZZ.ZZZ is not being advertised out, only the aggregate is.
What am I doing wrong?
Correct Answer by Harold Ritter about 8 years 3 months ago
Joe,
That is correct. You could redistribute the /32 selectively using a route-map but it would be safer to use a network statement for that specific /32 though.
Overall Rating: 5 (1 ratings)
Harold Ritter Mon, 02/09/2009 - 11:09
  • Cisco Employee,
Joe,
How do you originate the /32 prefix. You need to make sure it is in the RIB and that you use a network statement or that you redistribute it in BGP.
Also make sure that you have a "neighbor send-community" if you want the ISP to receive the community that you set in the route-map. The community will not be sent by default.
joemarr_brodart Mon, 02/09/2009 - 11:16
I've tried 2 methods:
* The IP is part of a /XX that is assigned to a port in our network, which is redistributed (and seen by the BGP routers) into our network via OSPF. This is prefered over the next option.
* null routing the IP on the routers doing BGP.
Harold Ritter Mon, 02/09/2009 - 11:23
  • Cisco Employee,
Joe,
If the /32 is not present in BGP then it cannot be advertised to your ISP.
Do you see the /32 in your BGP table (show ip bgp)?
joemarr_brodart Mon, 02/09/2009 - 11:37
duh,
no I only see the /18 :(
So, between the network command and the null route, I'm redistributing the /18 into BGP.
So I would need to some how redistribute the IP into BGP. I assume I dont want to redistribute my entire OSPF table for various reasons, but I could redistribute the /32 using a route-map, yes?
say
router bgp XXXX
redistribute static route-map static-routes
route-map static-routes permit 10
match ip address prefix-list ISP-Blackhole
Correct Answer
Harold Ritter Mon, 02/09/2009 - 11:40
  • Cisco Employee,
Joe,
joemarr_brodart Mon, 02/09/2009 - 11:41
I'll give it some thought regarding network statement vs. route-map.
Thanks for the help.
Mohamed Sobair Mon, 02/09/2009 - 11:34
  • Gold, 750 points or more
1- First of all You have to advertise ZZZ Network to ur BGP neighbor, as its not seem to be in the IP routing neither advertised . verify...
2- Ur XXX Network is not advertised but rather dropped due to the Nullo static route which preffered over the BGP AD.
3- U have to send community 2 the neighbor.
Mohamed
